Category: LiveConfig
Created: 2022-05-17
This article describes what to do if you find the error message Database exception: database disk image is malformed in your LiveConfig log (/var/log/liveconfig/liveconfig.log).
There are numerous reasons for a corrupted database file, SQLite even provides a separate article on that. Regarding LiveConfig, the most common reasons are
lcdbbackup, but just copied the database file)liveconfig.db-journal)To correctly and safely backup the LiveConfig database, you need to run /usr/lib/liveconfig/lcdbbackup (installed together with LiveConfig, see its man page for usage details).
Quit LiveConfig, so that the database is not accessed any more:
root@srv:~# systemctl stop liveconfig
Make a backup of the database file
root@srv:~# cp -av /var/lib/liveconfig/liveconfig.db /var/lib/liveconfig/liveconfig.db.BACKUP
Open the database with SQLite (you propably need to install the package sqlite3 first)
root@srv:~# sqlite3 /var/lib/liveconfig/liveconfig.db
SQLite version 3.27.2 2019-02-25 16:06:06
Enter ".help" for usage hints.
sqlite>
Now run the SQL command PRAGMA integrity_check;
If everything is ok, then it returns just ok. You may leave SQLite with the command .quit.
If the integrity check from step 4 returned any error, create a SQL dump using the following commands:
sqlite> .output /var/lib/liveconfig/liveconfig.db.sql
sqlite> .dump
sqlite> .quit
Then rename the corrupt database file, and import the SQL dump:
root@srv:~# mv /var/lib/liveconfig/liveconfig.db /var/lib/liveconfig/liveconfig.db.corrupt
root@srv:~# mv /var/lib/liveconfig/liveconfig.db-journal /var/lib/liveconfig/liveconfig.db-journal.corrupt
root@srv:~# sqlite3 /var/lib/liveconfig/liveconfig.db </var/lib/liveconfig/liveconfig.db.sql
root@srv:~# chown liveconfig:liveconfig /var/lib/liveconfig/liveconfig.db*
root@srv:~# chmod 600 /var/lib/liveconfig/liveconfig.db*
This should solve the problem. Start LiveConfig and check if everything is ok again.
root@srv:~# systemctl start liveconfig
